Problem with monitoring PPoE WAN connection on RV180 via SNMP
bentsi001
I am trying to monitor via SNMP PPoE WAN connection on RV180.
I have two issues:
  1. When connection is disconnected (pressing disconnect button in the web interface), interface #11 disappears from SNMP.
  2. operStatus is down while connection is working
Does somebody have any ideas why it is happening? I have router of other vendor and this kind of behaviour does not happen there.
Firmware version 1.0.3.10
IF-MIB::ifAdminStatus.1 = INTEGER: up(1)
IF-MIB::ifAdminStatus.2 = INTEGER: down(2)
IF-MIB::ifAdminStatus.3 = INTEGER: down(2)
IF-MIB::ifAdminStatus.4 = INTEGER: up(1)
IF-MIB::ifAdminStatus.5 = INTEGER: up(1)
IF-MIB::ifAdminStatus.6 = INTEGER: down(2)
IF-MIB::ifAdminStatus.7 = INTEGER: down(2)
IF-MIB::ifAdminStatus.8 = INTEGER: down(2)
IF-MIB::ifAdminStatus.9 = INTEGER: up(1)
IF-MIB::ifAdminStatus.10 = INTEGER: up(1)
IF-MIB::ifAdminStatus.11 = INTEGER: up(1)
IF-MIB::ifOperStatus.1 = INTEGER: up(1)
IF-MIB::ifOperStatus.2 = INTEGER: down(2)
IF-MIB::ifOperStatus.3 = INTEGER: down(2)
IF-MIB::ifOperStatus.4 = INTEGER: up(1)
IF-MIB::ifOperStatus.5 = INTEGER: up(1)
IF-MIB::ifOperStatus.6 = INTEGER: down(2)
IF-MIB::ifOperStatus.7 = INTEGER: down(2)
IF-MIB::ifOperStatus.8 = INTEGER: down(2)
IF-MIB::ifOperStatus.9 = INTEGER: up(1)
IF-MIB::ifOperStatus.10 = INTEGER: up(1)
IF-MIB::ifOperStatus.11 = INTEGER: down(2)
Log is full of these messages:
Wed Jan 22 12:57:21 2014(GMT) [rv180][Kernel][KERNEL] [ 2605.430000] pppoe_sid_index=1
Wed Jan 22 12:57:31 2014(GMT) [rv180][Kernel][KERNEL] [ 2615.520000] pppoe_sid_index=1
Wed Jan 22 12:57:47 2014(GMT) [rv180][Kernel][KERNEL] [ 2632.680000] pppoe_sid_index=1
Wed Jan 22 12:58:55 2014(GMT) [rv180][Kernel][KERNEL] [ 2695.530000] cmd 35313 is not SIOCDEVPRIVATE(35312)
Wed Jan 22 12:27:23 2014(GMT) [rv180][Kernel][KERNEL] [  785.160000] cmd 35313 is not SIOCDEVPRIVATE(35312)
johmuell
Your best bet would be to give us a call at 1-866-606-1866 and open a case so we can work on the issue a little more in depth than we could on the support forums.
