Problem with RV320 Gateway and sg300-28P L3
fbarducci
Hi, I created a network with a multilayer sg300-28P in layer 3 with the following vlan:
vlan 10
interface vlan 10
ip address 192.168.10.1 255.255.255.0
vlan 100
interface vlan 100
ip address 192.168.100.1 255.255.255.0
vlan 110
interface vlan 110
ip address 192.168.110.1 255.255.255.0
vlan 4 as a link to rv320
interface vlan 4
ip address 192.168.1.2 255.255.255.0
I set a static route on the SG300 as the default route:
ip route 0.0.0.0 0.0.0.0 192.168.1.1 <---- ip of rv320
I have configured rv320 with vlan 4 not tagged on port 1 by assigning this vlan to ip address 192.168.1.1.
I configured advanced routing on rv320 by entering as ip address 192.168.0.0 and as subnet 255.255.0.0 and gateway 192.168.1.2 <--- ip of the SG300.
The result is that from the console of the SG300 I can ping IP address 192.168.1.1 via interface 192.168.1.2 but I can not ping 192.168.1.1 from any of the other vlan.
What could be the problem?
thank you
5 Replies 5
Seb Rupik
Hi there,
Can you attach the full running config of the SG300?
cheers,
Seb.
hi,
thank you for help.
This is a configuration of sg300:
v1.4.8.6 / R800_NIK_1_4_202_008
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 4,10,100,110
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp server
ip dhcp excluded-address 192.168.100.1 192.168.100.1
ip dhcp pool network Office
address low 192.168.100.200 high 192.168.100.230 255.255.255.0
default-router 192.168.100.1
dns-server 192.168.1.1
exit
bonjour interface range vlan 1
hostname SG300
username cisco password encrypted  privilege 15
ip ssh port 22
ip ssh server
interface vlan 1
 no ip address dhcp
interface vlan 4
 name LinkL3RV320
interface vlan 10
 name MGMT
 ip address 192.168.10.2 255.255.255.0
interface vlan 100
 name Office
interface vlan 110
 name Printers
interface gigabitethernet1
 switchport trunk allowed vlan add 100
 switchport trunk native vlan 10
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
 channel-group 1 mode auto
 switchport mode access
interface gigabitethernet5
interface gigabitethernet6
 switchport access vlan 10
interface gigabitethernet7
 switchport access vlan 110
interface gigabitethernet8
 switchport access vlan 100
interface gigabitethernet9
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet12
interface gigabitethernet19
interface gigabitethernet24
interface gigabitethernet25
 switchport access vlan 4
interface gigabitethernet26
interface gigabitethernet27
interface gigabitethernet28
interface Port-channel1
exit
ip default-gateway 192.168.1.1
Are the other devices in VLAN100 directly attached to the switch? If so, are they configured to receive tagged packets?
cheers,
Seb.
hi,
The only devices that are connected and include the tag are the access points that have vlan native 10 ie management while tag 100. Devices within the sg300 switch can reach everyone else quietly. They also succeed in reaching the address of SG300 192.168.1.2 but fail to reach the address 192.168.1.1 which corresponds to the rv320.
I currently have a RV320 router setup with a SG300-28 switch in layer 3 mode.
I am using a tagged VLAN for my router VLAN.  The only thing which comes to mind, is do you have a route statement on the RV320 for network IP address (192.168.100.0) of VLAN100 poining to 192.168.1.2(VLAN4 IP ) so there is a path back to the switch?
You also need a route statement on the RV320 for each network not directly connected to the RV320 router.
PS
I noticed you are passing out 192.168.100.1 as your default router IP.  I use the switch's VLAN IP address for each VLAN.  So there is a different default gateway for each VLAN scope on DHCP.
