Reboot cisco router model RV180 via SNMP
lishao.lee
Hi Support,
Just wish to check if you could provide the OID and MIB for the cisco router model RV180, I have enabled SNMP service from the router but I still have issues to control the router through SNMP.
I would like to use SNMP to reboot the router, SNMP is enabled and the config are updated on the RV180, somehow the command below is not working.  Any ideas ?
Cheers.
$ sudo snmpset -v2c -c 'rwcommunity' 172.16.1.1 .1.3.6.1.4.1.9.2.9.9.0 i 2
Error in packet.
Reason: notWritable (That object does not support modification)
Failed object: SNMPv2-SMI::enterprises.9.2.9.9.0
0 Replies 0
