Remote to office with RVO16
grobert51
I am trying to connect to my office computer and am having difficulties.  I installed an RVO16 router and setup the local lan and wan and all users in the office have internet connections.  I need instruction on how to access my desktop (with a listening port in the registry)remotely using my home computer. I need to setup about 10 users to do the same.  Can anyone help me?  I'm lost.
Thank you
cristgon
Hello grobert51,
Thank you for using the Cisco Small Business forums. My name is Cristian, I am an eContent developer and I am part of the Small Business Support Community. There are a couple ways you can go about this. You could set up a client to gateway VPN, this is probably your easiest and best bet. You could also set up port forwarding to connect to the different work stations, this is a more tedious task and not a dynamic solution like the VPN would be. Here are some article links from our knowledge base to get you started:
You also want to enable remote access on your work stations, here are the how to's for Windows/OSX:
I hope you will find this answer useful, and I hope you reply back with any questions or concerns.
*Please mark the question as Answered or rate it so other users can benefit from it*
Cristian Gonzalez
Cisco eContent Developer
Glenn Martin
Repost Discussion to Small Business Routers community.
