Replaced Router - Port Fowarding wont work RV042G
bobbob111
Replaced an RV220W with a RV042G.
We had a dozen or so Port Forwarding rules in place. None of them are working on the new router.
For Example, port 3350 might forward to workstation at 192.168.0.40 and we had remote desktop setup with port 3350 on that machine.
These all worked fine before.
So i setup a service like 3350 for port 3350-3350. Then setup forwarding using that service to local ip x.x.x.x
Try to connect in from the outside...nothing
Saw someone saying to do it using UPnP, did that too. nothing.
Pics are attached
Note that all our internal is correct. Port for RDP on each machine changes, etc. It was all working with previous router.
Any ideas? I have done this many times, all looks correct. Also ISP is not blocking anything as it works if we put the old router back.
bobbob111
So apparently it came down to Disable Stateful Packet Inspection in the Firewall.
