Route specific ip address to a specific wan port.
wguitard1
I use a router RV082 with load balancing. My problem is when I try to access a specific site, I get the error message that my IP address changes and I can not use 2 ip address. I want to specify an ip range to always use the same WAN port.
Can you help me with the configuration I have to do?
Thank you!
Te-Kai Liu
Level 7
Level 7
Dual WAN>Protocol Binding is the page you are looking for.
Thank you for your response. Can tell me how by an example, my attempts were unsuccessful.
