Router RV180W - Can access Wireless PCs only from a Wired PC
martin100181
Dear Community, this is my issue:
Configuration:
1 Workgroup
7 PCs: 2 wired to the router + 5 Wireless + 1 HP Wireless Printer
All of them get IP through DHCP
Firewalls on computers are disabled.
Situation:
When I open an Windows Explorer, under my network I can see every PC from any other PC. But I can only access files and shared devices from wired PCs to wireless ones or from wireless PCs to wired PCs.
If I try to access any of the wireless PCs from another wireless PC I get a message saying its not reachable. Also can't ping them. Same situation with the wireless printer, I can only access it from wired PCs but not from WIFI ones.
WIRED TO WIRELES: yes
WIRELESS TO WIRED: yes
WIRED TO WIRED: yes
WIRELESS TO WIRELESS: no
This started when we migrated from a basic home router to a CISCO RV180W, so I understand that some configuration must be wrong.
Thank you in advance for any help you can give me.
Mehdi Boukraa
Hi Martin,
Please ensure that you have  "Wireless Isolation within SSID " is set to disable, this option is under Wireless --> Basic Settings --> choose your SSID --> edit and then disable Wireless Isolation"
Please share with us your result after testing
Please rate this post or marked as answered to help other Cisco customers
Greetings
Mehdi
Mehdi Boukraa
Hi Martin,
Greetings
Mehdi
Hello Mehdi, thank you for your answer.
Wireless Isolation is enabled, but when I edit the connection can only change SSID name and VLAN but can't dissable Isolation.
Could you please help me find how to dissable it?
BR
Martin
EDIT: Is under Security Configuration. It solved the problem, thank you so much for your help.
