rv016 not accessing sites
Waxxmann9299
i have rv016 v03 upgraded to latest fw..
i have only 1 WAN connection.
previously using rv016 v01 .. never had problems like this.
tried pinging the site(s) i cannot access using diagnostics.. no problems.
i connected straight to the router where the rv016 is connected.. i am able to access the sites without any problems.
i have firewall on, i did turn it on and off. same problem.. still cannot access sites.
LJ Gabrillo
Level 5
Level 5
Have you configured NAT?
Kindly check your configuration
Pinging in the router-VPN will always work, thus you may have lacking configuration on your device
To add make sure that your PC has the correct IP and gateway
please close case..
was able to check settings on my mac.. subnet settings at fault.
thanks
