10-31-2014 07:15 AM
Since 2 week I have some problem with my voip provider .
In my pabx software (3cx) my voip provider is correctly register but sometimes i dont know why I can't received external to internal call.
When i call my voip provider he tell me to disable sip alg of my router but in my RV016 i don't find any option sip alg.
How must i do?
My voip provider tell me to do the command line
no ip nat service sip udp port 5060
in telnet but i search and i can't acces telnet because i don't know login/password
Thanks for your help
Best Regard
Loic
Solved! Go to Solution.
10-31-2014 08:37 AM
Hi Loic,
Can you try please from the browser : https://IPaddress_of_rv016/f_general_hidden.htm
You will see the SIP ALG option
Please rate the post or mark as answered to help other Cisco Customers
thanks
Mehdi
10-31-2014 08:37 AM
Hi Loic,
thanks
Mehdi
10-31-2014 08:42 AM
Hi Mboukraa
It's works perfectly
thank you for your help
