RV042 blinking System+DIAG, no Network connection
LaVi
after a power cut my RV042 isn't working anymore.
When plugged into power the System and DIAG Leds are flashing (fast) from the first moment on.
I hav tried to access the router over it's normal IP and the reset one.
Tried 30/30/30 and 30/5/5 restets.
When i connect my computer (only my network card active, Static IP) to the routers LAN ports (tested all) Windows just says there is no network cable attached.
So i cannot even ping or tftp into the router.
Now i bought a second one from ebay .... same.
So i guess i'm doing something wrong?!
Please help!
Greggo
I have the same problem.
Unplugged the unit unit to change some cabling. Would not come back up. Tried everything, dead.
I bought a brand new RV042G, and it has issues.
Anybody have any other suggestions to recover the RV042? It has been a great little unit until now.
