RV042 - DIAG led light amber .?!!! NOT DOCUMENTED IN USER MANUAL !!
tom616161
On my RV042 (I used it for a couple of years now without issues), the DIAG led light amber (steady). It's not documented in the user manual.
User manual says only:
Diag  (Red)  The Diag LED lights up when the Router is not ready for use. It turns off when the Router is ready for use."
Router does not work anymore and I can't access its web page as I used to do before this problem.
I did a reset to factory default (reset button hold for more than 30 sec.) but it didn't change anything.
Any idea?
Thank,
Pierre.
Te-Kai Liu
Level 7
Level 7
When the DIAG LED lit solid, the error is not recoverable.
Is the device still under warranty?
Hello Tekliu,
Thank you very much for the answer.
Unfortunately it is not under warranty anymore!!!!!
I bought it second hand ± few years ago.
Have a great day,
Pierre
