RV042 does not working when using more then 5 ipsec tunnel
SNTPL
 I am using RV042 Dual band Routers in my multiple site, when i am trying to connect all router through ip Sec tunnel only 5 tunnel is working rest others are disconnect, some one help me.
Jorge Obregon
accordding to the Datasheet for this device, this should be able to connect 50 tunels
"50 IPsec site-to-site tunnels for branch office connectivity"
so it's hard to give you advises if you are configuring the rest of the tunnels the same way.
I would just advise you to activate the logs or do a packet capture and give us a call to 1866-606-1866 so we can open a case nad help you out with this issue.
thank you for contacting Cisco Small Business Support Center
I have logged a case in Cisco small business support but not getting valid answer, they told that 4 ports (50,51,500,4500) is block by ISP so it  creates problem but if ports block is problem then why some tunnels is working fine.
I am sorry to hear that, based on what you are telling us and based on my experience I would say that when a ISP is blocking those ports VPN tunnel wont work.
if you can share with me the case number so I can take a look at the resolution history and depending on that give you some advises.
thanks
However the way I would approach this setup is to configure the RV042 first as it is not as robust as the ASA firewall for encryption options.  If applicable.
Below is what I would verify that the ASA matches what you have configured on the RV042, besides having the local and remote IPs and local subnets configured correctly.
Phase1 DH Group:
Phase1 Encryption:
Phase1 Authentication:
Phase1 SA Life Time ___ seconds
Phase2 DH Group:
Phase2 Encryption:
Phase2 Authentication:
Phase2 SA Life Time  seconds
Preshared Key:
If the configuration is correct, then I tend to see that the RV042 model needs to be power cycled to negotiate the tunnel.  You may need to do both sides sometimes.
