RV042 firewall blocks most traffic when deny rules are created
justin_h
I am configuring an RV042 firewall.  I am trying to whitelist as many ports as possible, but whenever I create a deny, it seems to block all traffic.  I did change the priorities because firewalls read rules from top to bottom.  There are to subnets because one needs a connection to the Internet.  I am limited access between the two networks only to allow the necessary video ports to be open.  Under those (lower priority) rules, I added a deny rule to block the rest of the ports between the subnets and later on, I created an explicit deny all.  With any deny rule, all traffic between the networks are blocked.
Why are the deny rules blocking traffic when there are allow rules with a higher priority?  And by higher, I mean above the deny rules with a lower number.  Rules (priority #) 3-10 allow traffic between the two networks, but rule (priority) 11, the deny rule to block the rest of the traffic between the networks seems to block all.  Should I 'assume' the implicit deny all is working and only whitelist the allowed ports?
Justin
Iliya Gatsev
My name is Iliya Gatsev from Cisco Technical Support Team.
I think it would be best if you could call our support line and open a support ticket, so we can do a WebEx remote session and check the configuration.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
