Hi there.
My problem is as follows
Setting the device up with static WAN is no problem, I get internet access and everything works perfect - using WAN1.
But when connecting a LAN port to a switch with a dmz lan, the WAN port looses connection
The LAN address of the RV042 VPN Router is set to: 10.10.20.5 with subnet 255.255.255.248
Other equipment is connected to the switch with 10.10.20.6, 10.10.20.4 and 10.10.20.2 with same subnet.
10.10.20.2 is a routing device that connects to 172.16.10.2 and further to 10.10.10.2 (LAN) with servers
The device working mode is currently set as Router. Setting it as gateway makes no difference to the problem.
Can you clarify what goes wrong?
