I run a Cisco RV042G with v4.2.1.02 firmware.
IPv4 runs fine and I now activated 6to4.
The router can be found as fc00::1 but also delivers 2002 numbers in the LAN.
But when I do a ping6, a traceroute6 or try to open one of the ipv6 test pages, nothing happens.
From the traceroute6 result it looks to me, that the routing stops right at the router and is not delivered through the 6to4 tunnel.
Do I have to set another route?
Setup --> Advanced Routing --> View shows:
:: | 96 | * | 256 | tun64 |
2002:4b15:12d5:: | 48 | * | 1024 | eth0 |
2002:: | 16 | * | 256 | tun64 |
fc00:: | 7 | * | 256 | eth0 |
fe80:: | 64 | * | 256 | eth0 |
fe80:: | 64 | * | 256 | eth1 |
fe80:: | 64 | * | 256 | tun64 |
ff02::1 | 128 | ff02::1 | 0 | eth1 |
ff02::1 | 128 | ff02::1 | 0 | eth0 |
ff02::c | 128 | ff02::c | 0 | eth0 |
ff02::1:ff10:345 | 128 | ff02::1:ff10:345 | 0 | eth1 |
ff02::1:ff3c:ee2c | 128 | ff02::1:ff3c:ee2c | 0 | eth1 |
ff02::1:ff43:82ea | 128 | ff02::1:ff43:82ea | 0 | eth1 |
ff02::1:ff91:ca91 | 128 | ff02::1:ff91:ca91 | 0 | eth1 |
ff02::1:ff95:d52 | 128 | ff02::1:ff95:d52 | 0 | eth1 |
ff02::1:ff9f:dda3 | 128 | ff02::1:ff9f:dda3 | 0 | eth1 |
ff02::1:ffae:cf43 | 128 | ff02::1:ffae:cf43 | 0 | eth1 |
ff02::1:ffaf:f523 | 128 | ff02::1:ffaf:f523 | 0 | eth1 |
ff02::1:ffb0:b101 | 128 | ff02::1:ffb0:b101 | 0 | eth1 |
ff02::1:ffb3:5d9a | 128 | ff02::1:ffb3:5d9a | 0 | eth1 |
ff02::1:ffc9:b323 | 128 | ff02::1:ffc9:b323 | 0 | eth1 |
ff02::1:ffd3:97a3 | 128 | ff02::1:ffd3:97a3 | 0 | eth1 |
ff02::1:ffd9:9d1b | 128 | ff02::1:ffd9:9d1b | 0 | eth1 |
ff02::1:fffe:bc80 | 128 | ff02::1:fffe:bc80 | 0 | eth1 |
ff00:: | 8 | * | 256 | eth0 |
ff00:: | 8 | * | 256 | eth1 |
ff00:: | 8 | * | 256 | tun64 |
default | 0 | ::c058:6301 | 60 | tun64 |
Thanx,
Steff
