Rv082 firewall rule not working
aa
Hello, i have a Cisco Rv082 with Firmware v4.0.4.02-tm (Jul 4 2011 13:30:56)
I have configure WAN1 with a public IP and netmask 255.255.255.252. (Only one public IP in use)
Internally the LAN is a 192.168.169.0/255.255.255.0
I need to add some rules like
Service: HTTP
Interface: WAN1
To: 192.168.169.2
But after rule configured the connection still not working, it only works when I add a port forwarding.
For HTTP maybe port forwarding is OK, but other services I need to grant access to a specific public IP address, not to everyone.
So I need the Firewall rule, but is not working, it always block the request.
In the Firewall rule list I have 3 default rules:
Allow All Traffic LAN Any Any Always
Deny All Traffic WAN1 Any Any Always
Deny All Traffic WAN2 Any Any Always
But those rules cant be deleted or edited
Any help will be appreciated
Thanks!
Te-Kai Liu
Level 7
Level 7
Here you can find an example about how to add access rules on top of a port forwarding rule.
https://supportforums.cisco.com/message/3453760#3453760
Hello Te-Kai Liu,
I tried to set up rules as you explained in a RV042 using the latest available firmware and configured as gateway.
Unfortunately things do not seem to work as expected. I want to be able to accept and forward ssh connections originated from ip1 only. An ssh connection from a different ip address must be rejected. So I setup:
- port 22 forwarding to my internat ssh server, it works
- a first rule (priority 1) allowing ssh requests from ip1 on port wan1`to be accepted. More precisely:
Priority1
EnableYes
ActionAllow
ServiceSSH [22]
Source InterfaceWAN1
Sourceip1~ip1
Destinationwan1_ip~wan1_ip
TimeAlways
- a second rule (priority 2) denying any ssh on port wan1:
Priority2
EnableYes
ActionDeny
ServiceSSH [22]
Sourceany
TimeAlways
With this configuration, every external ip (and not only ip1) get ssh redirected, so it's not filtered out.
If I modify the DENY rule changing Destination from "wan1_ip~wan1_ip" to "any" (I don't even know if such a rule is meaningful), then EVERY ip (including ip1) get discarded when trying to ssh-connect.
So I'm unable to setup proper ip-based firewalling. Can you help please?
Thanks a lot,
Alberto
