566
RV0xx VPN Problem using SIP
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-19-2012 08:24 PM
Hello
I installed a RV082 on my main office and a RV042 on a branch office, implemented a VPN so I connect an Aterisk in each side and I configured a voice trunk between those Asterisk, it works fine until something happens and it stops routing SIP traffic even the VPN link seems to be fine I can ping the asterisk server from each other but the sip traffic doesn't work
Also another symptom is that I can't disconnect the vpn, if I try to do it is says a message that says wait and disconnecting but the status doesn't change.
I can solve the problem by restarting the routers at both sides.
Labels:
- Labels:
Small Business Routers
0 Replies 0
