RV110W Number of Forward Rules
fraschizzato
Is possible to configure more than 40 forward rules (20 in single port forward and 20 in port-range forward)?
If it is possible how I can do it?
linksysinfo
Level 4
Level 4
Are all the ports for one IP?
Regards Simon
http://www.linksysinfo.org
Regards Simon
No, any forward is for a different IP. The devices are IP cameras and wifi access point. I would like to access them from outside the lan by using dyndns and port forward. For the first 40 devices there is no problem, but for the others I cannot set up more forward rules.
You have probably hit the maximum number of port forwarding rules. Since RV110W supports PPTP VPN server, you could connect to RV110W over a PPTP tunnel and access the administrative interface of your cameras and access points from the LAN side.
