I recently upgraded my RV120W firmware from 1.0.2.6 to 1.0.3.10. While the upgrade appeared to occur normally, once complete the login page did not reappear. Following a manual reboot using the on/off switch, I can no longer contact the router nor will any device recieve an IP address. Wireless is also not functioning although the light is on. The power light was slowly blinking, although it settles down to steady. Depressing the reset button has no apparent effect on the operation. Are there any next steps I can try to attempt to recover the router? Thanks!
