RV130 Point-to-Point VPN
johne5s010101
I have a new VPN to setup in a cisco rv130 to a remote 3rd party business that runs a server that we need to connect to.  After I input all the VPN connection info and enable the tunnel I lose almost all LAN connectivity.  I receive DHCP from the router and that's it.  No Internet access. can't even ping or login to the router.  I can ping across the VPN to the remote server.  So the tunnel is up.
It seams that the vpn route has priority over the LAN.  How do I change this? How do I only use the vpn to get to the remote server and leave the internal LAN alone.
I have defaulted the router and plugged in the vpn info with the same results.
i'm running the latest firmware 1.0.2.7
Thanks John
johne5s010101
a new ver of the RV130 come out last week,  Upgraded the router and still no help.
now the router is at 1.0.3.14
any help at all?
When ever I enable the Point to Point VPN, the router reverts all traffic across the vpn,  how do I stop it from doing this?
John
