02-16-2019 06:47 AM
I purchased a RV130W and we're having some difficulties configureing the device to work as desired.
We have two vlans: 10 and 20.
10 is for our clients.
20 is for a printer and file server.
We want traffic to be able to flow freely to the vlan 20 servers from vlan 10, but not originate from the vlan 20 to vlan 10.
The idea was to enable inter-vlan routing and then limit traffic from vlan 20 with an ACL. Traffic could then still originate from vlan 10 to 20 and SPI would allow return traffic. Turns out the ACL is limited and we cant create from from DMZ > LAN.
And the device seeems to only allow one DMZ hosts.
Any idea how to solve this?
02-16-2019 09:30 AM
Hi @Lau Fischer,
Check this link:
https://community.cisco.com/legacyfs/online/add_and_configure_access_rules_on_rv130_and_rv130w_0.pdf
I hope can help you.
02-16-2019 10:35 AM
Hello Luis,
Thanks for the suggestion.
Unfortunately, the ACL only seems to do from DMZ->WAN or LAN -> WAN or WAN-> LAN/DMZ
I need an ACL to limit traffic from DMZ->LAN.
