RV132W - Scheduling Management problems
RadioTechnician
Hello Community,
We use an RV132W to share the same FM-broadcast transmitter between multiple radio stations, based on a fixed schedule usingthe Scheduling Management/Access Rules of the RV132W. Transmission to the FM-transmitter happens via IP implicit.
Example: A schedule could be Radio1 gets access from 01:00 pm to 01:59 pm and Radio2 from 02:00 pm to 03:59 pm etc.
The schedules are based on a general Access Rule of Always Block of the radio station IP-addresses, hence the specific access is based on Allow by Schedule.
Our problem is that the Firewall does not cut off the access according to the Schedule Management - in other words, it stays connected. In the above example, Radio1 continues to get access to the FM-transmitter even after 02:00 pm, and Radio2 does not get access when it should. After a random number of minutes, the switch happens.
It is like the RV132W is not checking the Schedule Management regularly.
Any help is much appreciated.
0 Replies 0
