RV180 blinking or flashes on Power LED and Wireless LED
gilaganja
I have a new router RV180W, the problem is show up after I configure  RV180W for the first time after I reboot the router. The LED Power and  Wireless is blinking or flashes so I can't access my router via LAN  Port. I try to reset to factory defaults by press the reset button but  it still doesn't work. Help me to fix this problem what should I do ?
6 Replies 6
mpyhala
Level 7
Level 7
Dido,
Hold the reset button for 12 seconds with the router powered on. It should reset to factory defaults.
- Marty
I have the same problem on my Cisco WRV210 when I enabled WMM it completely locked and I cant access it via Lan and the wireless isn't turning on even the reset wont work.
Alvaro,
From the WRV210 Quick Start Guide:
• Factory reset—Press the button for approximately 15 seconds to reset
the router to the factory default settings. You can also restore the
factory default settings from the Administration > Factory Defaults page
in the web-based Configuration Utility.
Try that and see if it will reset. If not, post your serial number or call support to see if your device is under warranty.
www.cisco.com/go/sbsc
- Marty
Serial Number is GSZ15140000
Alvaro,
Covered under warranty
Please call support for assistance.
- Marty
I developed the same issue after a power loss to our area.  Any chance that someone can help?
