04-28-2012 08:02 AM
Does the Cisco RV180 firewall/router support DHCP client on the WAN interface? This is specifically mentioned on the DHCPv6 client, however, it is not mentioned for the IPv4 client. I'd like to set it up using my cable modem in bridged mode connecting it to the WAN interface on the RV180? So I'd get the IP address from my ISP.
Niels
Solved! Go to Solution.
04-29-2012 09:21 PM
Hello Niels,
The RV180W certainly can pick up a DHCP address from your ISP on the WAN interface, through a bridged modem. In fact, this is the default configuration. Of course, you can also change your connection type to a static IP address or PPPoE connection profile (DSL).
All of our Small Business routers are definately capable of this confiugartion. Personally, I currently use a RV180W with a cable connection. The RV180W picked up the public IP address from my ISP just fine.
All the best,
-David Aguilar
Cisco Small Business Support Center
1-866-606-1866
04-29-2012 09:21 PM
Hello Niels,
All the best,
-David Aguilar
1-866-606-1866
05-02-2012 02:03 PM
Thank you very much!
I actually found it in the manual, I overlooked it the first time I read the manual.
It should hopefully be on its way to me shortly
Cheers,
Niels
