RV180 port forwarding doesn't work
mattiassercu
Today i installed an RV180 VPN router as replacement for a netscreen ns-5GT.
Exactly the same configuration, everything works, except port forwarding from WAN to a host inside NAT.
My ports are open (online port-scanner sees the ports as open), the hosts are accepting connections, but a connection can't be made.
Probably a bug in the firmware.
32 Replies 32
Greg,
From the postings of mattiassercu and Banjamin Lin, it appears that RV180 firmware 1.0.2.2 fixed the port forwarding issue with PPPoE WAN connection type. If you believe you are experiencing the same issue, you could please contact the Small Business Support Center to request the beta firmware. As far as I know, the next official firmware will take some more time to develop and test.
1. go to your RV180W VPN Firewall Console
2. Choose menu QoS
3. Global Settings: WAN QoS enable it
4. Save
5. Test the port forwarding, it functions!
I am experiencing the same issue.  I tried this but it does not work.  Is there any other solution?
