07-23-2012 05:00 AM
I am trying to set up RV180 @ 2 locations. I have setup Port forwarding for Remote Desktop 3389 (Defined as a custom srvice), FTP and HTTP. When I try to access these services from within LAN it works fine, however from any other location only FTP works and RDP and HTTP are rejected. I have a static IP address. I have tried with both Port Forwarding as well as Access Rules. Please help ASAP.
Operation succeeded
Action | Service | Status | Source IP | Destination IP | Internal Port | ||
Always Allow | HTTP | Enabled | Any | 192.168.2.50 | 80 | ||
Always Allow | FTP | Enabled | Any | 192.168.2.160 | 21 | ||
Always Allow | RDP | Enabled | Any | 192.168.2.163 | 3389 | ||
| Source IP | Destination IP | ||||
Always Allow | HTTP | Enabled | Inbound (WAN (Internet) > LAN (Local Network)) | Any | |||||
Always Allow | FTP | Enabled | Inbound (WAN (Internet) > LAN (Local Network)) | Any | |||||
Always Allow | RDP | Enabled | Inbound (WAN (Internet) > LAN (Local Network)) | Any |
09-24-2013 04:30 PM
Hey Luis,
Well done for figuring that one! In the meantime, you may wish to see if your firmware needs updating as it appears newer firmware has fixed this problem.
12-28-2013 12:33 PM
Update the firmware to the latest version (1.0.3.10 as of this writing). After reboot, delete the existing troublesome Fowarding rule(s), Custom service(s), and Access rule(s). Once deleted and saved, manually add back the Forwarding and Custom services rule(s) and the Access rule(s) will be auto-created and auto-enabled this time and all seem to work now (finally). This worked for me when following this order of steps.
