RV180 PPTP not working reliably
toltec_sf
I'm a newb to networking and am have the following issues with the PPTP server on the router:
1. Sometimes login hangs while loging in user. I dont really understand why sometimes it lets me connect, and not others. I have tried from different PC's and AP's and the only consistent thing is that it is not reliable.
2. When I've logged in, it does stay connected, but I cant access some internet sites (cant even ping them). Sometimes it actually gets to a point where I cant access anything (cant even ping internal remote LAN); the latter issues often occurs some time after I've been connected (~20min) although in all cases the PPTP connection remains intact.
After doing a lot of reading I've reduced the MTU multiple times on all interfaces involved and I cant see that it has helped. I've used an MTU as low as 1400 (which is quite a bit smaller than should be necessary based on the guidance I have read, tested using the ping command with "no fragment" set). I've also read about reducing the MSS, but I dont know how one can do that on the RV180.
Other information that may be useful:
1. I am using the latest firmware: 1.0.1.9
2. QVPN works fine (unfortunately it's not an option for secure web browsing the internet)
3. I've turned off all "attack prevention" in the firewall
4. As I've tried this in multiple locations getting the same result (sometimes working), it's not a simple port blocking issue or GRE issue. Also have disabled the PC firewall with no effect
Any help would be greatly appreciated as I'm stuck...
jurodri3
If you tell us that the error happens Sometimes and you already install the last firmware version. I would recommend
you to contact our cisco support team and open a case in order to report the failure and we will be happy to assist you.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Diego Rodriguez
Cisco network engineer
Thank you
