RV180 WAN speed issue
reflexivo
I've connected an RV180 to a 100mb symmetric leased line but we're not getting anywhere near that speed (more like 10mb). I selected this router because it's supposed to support that speed. Our provider told us to disable auto-negotiation on the WAN port which I have done, and also to set it to 100/full, but we then get no connection at all, and have to leave it on 1000/full. Wondering if anyone can suggest anything?
thanks
ivan98zzz
From http://www.smallnetbuilder.com/lanwan/lanwan-reviews/31746-cisco-rv180-vpn-router-reviewed?showall=&start=3, you can have a good feel of the network performance of RV180.
Definitely, there is something wrong if you're only getting 10Mbps or so.
Try disabling all firewall, QoS, and when you measure performance, try for a remote site as near as possible. If you're in USA, you won't want to use a speed test server in China, for example.
