RV180W and multiple VLAN's over same port (Trunking??)
MattyBoy4444
I have a RV180W and a EnGenius EAP350 Access Point.  The EnGenius supports multiple SSID's and VLAN tags them.  If port 1 on the RV180W has VLAN 1 untagged and VLAN2 tagged, any connection to the EnGenius always gets an IP from the VLAN 1, even though they are connected to the SSID which is tagged with VLAN2.  Has anyone else had this problem.
Thanks.
Te-Kai Liu
Level 7
Level 7
(I do not have any experience with EnGenius AP.)
If the AP is sending untagged packets to RV180W, it would explain why you saw the issue.
songster13
I have exact same problem, with WRVS4400N as access point (Using only LAN port).
I figured it out.  The EnGenius had a new firmware which was not documented with a new feature. By default the Multiple SSID's are not VLAN tagged. (Stupid) There was an Isolation box I needed to check for each SSID/VLAN
