03-18-2014 04:23 AM
Hello
After searching a lot in the Internet about my issue without any success, I have to start my own discussion.
I set up the PPTP-Server and created a PPTP-User as described in the admin manual of the RC180W-Router. I can connect to the router through the build in VPN-PPTP function in Windows 7 and on my Android phone. Then, I can also ping the router and access the Web Management. But I cannot access the other clients and servers in my network, nor ping them.
My configuration is as follow:
If I connect to my router with VPN, I get the following informations on Windows 7:
Once connected, I can ping the router and access the Web Management on IP 192.168.0.1
I cannot access or ping any other client or server, for example 192.168.0.96
Marco Spicer
Solved! Go to Solution.
03-18-2014 09:33 AM
Marco,
I have noticed that you are in the same subnet at the PPTP Server subnet. Connecting PPTP clients would need to be in a different subnet other than 192.168.0.X. So an acceptable PPTP server configuration could be in 192.168.1.x subnet, as long its not in the 192.168.0.X subnet. If this helps you and fixes your issue please mark your answer
03-18-2014 09:33 AM
Marco,
03-19-2014 03:03 AM
Thanks for your answer.
I changed the settings, so that the IP-range for PPTP is now from 192.168.4.1 to 192.168.4.6.
Still the same problem. I could ping and access the router at 192.168.0.1 but nothing else in the subnet 192.168.0.x
Then I created another VLAN for the subnet 192.168.4.x with enabled Inter-VLAN-Routing. And I also had to enable Inter-VLAN-Routing on my default VLAN (192.168.0.x). Now everything works perfect!
So, the solution is:
