RV220W connect to web interface problem
i.stanciu
I have an Cisco RV220W and I can’t connect to web interface. The router is new
I receive the error in Mozilla: Cannot communicate securely with peer: no common encryption algorithm(s).
I used also Internet Explorer, Chrome , I tried to disable SSL 3.0, TLS 1.0 but the problem persist.
The PC obtained IP address from the router, I have ping on it ,also the SSID is up with open network
I reset to factory default but the problem persist
I attached the error message
Please help me with an advice
Best regards
riroe
Level 3
Level 3
Just wanted to verify that you have your PC hard wired to one of the LAN potrs on the RV220?  Also what version of
I/E are you using. I/E version 7 usually works well with our routers.
THANKS
Rick Roe
Cisco Small Business Support Center
The PC it was connected to the router directly and received an IP address from DHCP
Conclusion : Hardware malfunction
I RMA the router with problems and the new one is OK
