RV220W mobile Users
dennisriedel
Hello together,
is it possible to share the same network segment like my lan for mobile users?
In a so called bridge mode?
I got a VPN tunnel to a customer from my local network and i need to access it within the mobile access.
I can not change the VPN Site to Site tunnel.
regards
Dennis
jasbryan
Level 6
Level 6
Dennis,
if im understanding you correctly- if you already have a site to site tunnel and if your mobile phone has wifi then you can use it like any other pc. now if you're on the road outside your local network you will not be able to use your phone to access information across the tunnel.
Jasbryan
Hello jasbryan,
no you don't.
I have a site to site vpn tunnel
trusted lan (192.168.30.x) ------ remote lan (172.20.1.x)
between these two ressources is a any vpn.
no I've got some mobile users (not mobile phone)
Users who use PPTP, QuickVPN or SSLVPN. Depends on which is best.
Is it possible for my PPTP Users to access the remote lan?
In my understanding I have to change the tunnel pairs (not possible) or I need to bridge the pptp users inside my network.
regards
