RV220W SSLVPN Problem
dennisriedel
Hello all,
I do not have a valid SSL Certificate on my firewall but I want to use SSLVPN.
If I connect to the IP adress and the SSLVPN Portal I can choose the sslclient launcher but after that I get a error that I need a internet explorer 64bit or that the active I was blocked because of a unsecure publisher.
what can I do?
regards
blwright
Dennis,
If you are using a 64 bit version of Windows below is the link for the SSL VPN connection workaround.
download  VC++ 2005 64-bit from Microsoft.
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=21254
If this does not resolve your issue please call the SBSC at 1.866.606.1866, open a ticket, and we will try to get the issue resolved for you as quickly as possible
Blake Wright
SBSC Network Engineer
