01-25-2012 08:30 AM
My ISP provides IPv6 connectivity in the form of dual stack IPv4/IPv6 with DHCPv6 Prefix Delegation. Using a Cisco IOS-based router I managed to make such a connection by using as a template the Cisco IOS configuration file that my ISP has posted as an example in the following link:
http://ipv6.otenet.gr/current-config.txt
The main point on this configuration is a PPPoE connection with:
interface Dialer46 ipv6 address autoconfig default ipv6 enable ipv6 dhcp client pd LAN_DHCP
interface Vlan1 description local LAN ipv6 address LAN_DHCP ::/64 eui-64 ipv6 enable ipv6 nd other-config-flag ipv6 dhcp server LAN_DHCP
I am now trying to configure an RV220W router on the same network but I cannot make it establish an IPv6 connection. Perhaps I am not setting it up correctly to make it work similarly to the Cisco IOS-based router. My settings are the following:
Networking -> IPv6 ->
IP Mode - IPv4 and IPv6 Dual-Stack
IPv6 WAN - DHCPv6 + Stateless Address Auto Configuration
IPv6 LAN - IPv6 Address: fec0::1, IPv6 Prefix Length: 64, DHCP Status: Enable DHCPv6 Server, DHCP Mode: Stateless, DNS Servers: Use DNS from ISP.
Router Advertisement: Status: Enable, Advertise Mode: Unsolicited Multicast
When I check the Summary page I see that although a have a proper working IPv4 connection, the IPv6 information is the following:
WAN (Internet) Information (IPv6)
Connection Time: 0 Days 00:07:10
Connection Type: Dynamic IP (DHCP)
Connection State: Connected
IP Address: fe80::5a8d:9ff:fee2:f9d3/64
Gateway: fe80::200:ff:fe00:0
DNS Servers:
which is of course wrong.
Could someone please help me to configure this router according the Cisco IOS configuration file I linked on the top in order to have a working IPv6 connection?
Solved! Go to Solution.
01-26-2012 12:30 AM
Hi Panos,
Thank you for posting. You can find a contact number for Cisco Small Business Support at the following page:
You will need a Cisco User ID (your login name) and the serial number of your router to open a case.
01-25-2012 11:50 PM
At least, does anyone know if this router supports a dual stack DHCPv6 Prefix Delegation connection? Can anyone please tell me how to open a support ticket to Cisco regarding this issue?
01-26-2012 12:30 AM
Hi Panos,
01-26-2012 02:37 AM
So, I did a WAN packet capture to see that type of DHCPv6 packets the router sends to the ISP in order to obtain an IPv6 address and I saw that the router is sending DHCPv6 solicitation packets of type IA_NA i.e. for Identity Association for Non-temporary Address. However, most ISPs that offer a dual stack IP4/IPv6 service, they use DHCPv6 Prefix Delegation in which case the router is expected to send DHCPv6 solicitation packets of type IA_PD i.e. for Identity Association for Prefix Delegation.
Therefore, this router does not support DHCPv6 Prefix Delegation services with firmware 1.0.3.5 and as a result in practice it is only good for tunnel IPv6 connections.
Are there any plans to provide support for Prefix Delegation?
03-02-2012 05:12 PM
This is a quick message to let anyone interested that the latest beta firmware 1.0.4.6 still does not support DHCPv6 Prefix Delegation.
