04-01-2020 10:22 PM
I have Cirsco RV320 , today i find that some of my VOIP phone does nor work properly i go into the RV320 and find that the DHCP table is empty ( you can see attched picture )
I restart the router twice and cant see the DHCP devices that on the network ,
all our end points on network do have internet we just have some issue with some IP phone and i think the empty table is the issue
04-02-2020 01:26 AM
- That depends it seems that no addresses are being allocated at all 1) Is the RV320 your intended DHCP server 2) Is the setup correct ?
M.
04-02-2020 01:26 AM
Please check the router for running firmware version and upgrade it to latest version - 1.5.1.05 if its older.
Link to download the latest firmware version 1.5.1.05 -
https://software.cisco.com/download/home/284005929/type/282465789/release/1.5.1.05?i=!pp
Link for steps to upgrade firmware on RV320 router -
In case you still face issue with DHCP after firmware upgrade, please follow below links for detailed information regarding DHCP settings on RV320 router. Kindly follow the links and verify the configuration done on the router for DHCP.
Refer page number 43- https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv320/administration/guide/en/Updated/rv32x_ag_en.pdf
