RV320 DMZ Configuration
calvinlui
I was having some trouble for setting up my RV320. I sub 16 IPs from telco. However, when I try to setup a DMZ with One-to-One NAT forwarding. I don't see the services works. Could you guys help to advise a bit?
Used the following
Interface IP # xxx.xxx.xxx.111
DMZ# xxx.xxx.xxx.112 - 124
I tried to NAT to 192.168.133.x Subnet with One to One NAT Mapped. I don't see the services can be connected from the Internet. See if you guys have any ideas..
6 Replies 6
cchamorr
Level 5
Level 5
I have a few questions:
1- What is the end goal?
2- Why using One to One NAT and DMZ at the same time?
3- Is the One to One NAT configuration working by itself without the DMZ?
With the answer to those questions I may be able to give you some ideas.
I would like to archive something similar. I have a /29 subnet from my ISP and would like to route the public addresses to a separate subnet which is on the DMZ interface (separate switch). How can I archive this One to One NAT or is there a better way? I attached a small diagram.
Thomas
How about this option:
1- Create a second VLAN on the router
2- Use the same subnet as the DMZ (Disable the DMZ)
3- Assign a port on the RV320 to the new VLAN
4- Connect your switch to that port
5- Setup One to One NAT to the desired addresses on the new VLAN
I hope this helps
I tried the same configuration as you mention, However it is still fail.
Could you please share more details about your configuration?
OKay.. here are the basic inform
192.168.1.x - Trust/ Server Zone
192.168.20.x - User Zone
192.168.133.x - DMZ
I am just wondering whats the best method to do the mapping. At the moment, I am placing 2 server at the DMZ only..
I do not preferred one to one nat mapping .. it might be not really secure at the first phase
