RV320 - remote management forbidden
avi.barilan
Hi all
i have setup a new rv320 router and i am having a little issue.
i am trying to get remote management working,
but when i try to access the router from wan i get a forbidden page
(screenshot attached)
i have setup PAT from 8443 to 443 for this particular function.
it doesnt seems to help, while other PAT's i created work as expected.
attaching my router config screenshots as well.
thanks in advance.
Matthew Needs
Hi, I'm not sure if you ever solved this? I have written the following document which might help..
https://community.cisco.com/t5/small-business-support-documents/how-to-lock-down-remote-access-and-change-the-access-port-number/ta-p/3715138
All the best!
