RV320 routing public IP addresses -PNAT
craigszcz
Hello, I have an RV320 and to connect to COMCAST broadband connection. COMCAST provides me with 5 IP address. I do not how to configure these IPs on the RV320 so I can connect through the broadband modem and even use these IPs for network address port address translation for internal IP addresses. is this possible?
Li Zhang
Yes it's possible.
For example, you can use one IP address for WAN port and the other four for 1-to-1 NAT. For 1-to-1 NAT configuration, please check:
http://sbkb.cisco.com/CiscoSB/ukp.aspx?vw=1&docid=f6916a7709cb43d38d74bd6ef3e8d0a2_Configure_One_toOne_Network_Address_Translation__NAT__on_RV3.xml&pid=4&respid=0&snid=2&dispid=0&cpage=search
