RV320 SNMPv1/v2c problem
fernandezjm
I have problems with the SNMPv1/v2c service in my RV320 (firmware V1.3.2.02). When I configure this service and It works fine, but after a few days the service does not respondTo make it work again, I have to disable the service and enable it again in the System Management > SNMP menú. After analyzing the failures I found that when there are many PPTP VPN accesses, the service fails because the number of ppp ports opened.
Have you experienced this problem? and do you know how to solve it?
Best regards
JM Fernandez
Iliya Gatsev
My name is Iliya Gatsev from Cisco Technical Support Team.
Please open a case with Cisco Technical Support. Here is the contact of the technical support :
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Iliya Gatsev
Cisco TAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
