RV320 VOIP in DMZ-port
radargatan
Hi all
I have set my WAN2-port as a DMZ-port and want to put my voip-adapter SPA112 in the DMZ-port
How do i configure my RV320 so the voip traffic goes from WAN1 to the DMZ port?
Michael Vandergrift
From the RV320 admin guide.
DMZ Enable
A DMZ is a subnetwork that is open to the public but behind the firewall. A DMZ
allows you to redirect packets coming into your WAN port to a specific IP address
in your LAN. You can configure firewall rules to allow access to specific services
and ports in the DMZ from both the LAN or WAN. In the event of an attack on any of
the DMZ nodes, the LAN is not necessarily vulnerable. We recommended that you
place hosts that must be exposed to the WAN (such as web or e-mail servers) in
the DMZ network.
To configure DMZ:
STEP 1 Choose Setup > Network and check Enable DMZ. A message appears.
STEP 2 Click Yes to accept the change.
STEP 3 Select the DMZ interface in the DMZ Settings table and click Edit. The Edit DMZ
Connection window appears.
STEP 4 Select Subnet to identify a subnetwork for DMZ services and enter the DMZ IP
Address and Subnet Mask. Or select Range to reserve a group of IP addresses
on the same subnetwork for DMZ services and enter the IP address range.
STEP 5 Click Save.
Well, it does not work as the admin guide says.
I will upgrade to the latest firmware first and test further and get back here if it does not work properly
