I habe 2 rv320 router in differents site.
version 1.3.1.10 firmware
I have 2 wan connections in each site connected in each router
I have actived the load balancing in actif/actif mode.
I have created a VPN with the two router in gateway to gateway mode.
I VPN don't route the flux randomly after 2 or 3 or 7 day.
After a reboot of the routers , the VPN come back Up and running.
Did we need to add static route on the router for the VPN subnet or is it automatci when you create the tunnel with the wizard ??
