RV320 - WAN1 PPPoE Status: Connected (Inactive)
andreig1978
Hi all,
As stated in the subject my Wan status appears as Connected (Inactive).
Other than that everything seems to be working fine.
Any ideeas?
I am using the latest firmware v1.1.1.06 (2013-12-06, 11:02:37) and the router is establishing a PPPoE connection through a GPON.
Thank you,
Andrei
andreig1978
In case someone stumbles into the same issue, my problem was with the "Network Service Detection" which was set by default to ping the default gateway - it didn't work in the case of my ISP.
I changed it to ping Remote Host: 8.8.8.8 and the status is now Connected.
Best,
Andrei
Andrei,
Thank you for sharing the fix.
- Marty
