RV325 Internet Speed connection only max 100mbps vs 300mbps (Direct to ONT). Need Help!
Dear All,
Is it the maximum for RV325 only 100mbps? or my setting was wrong? Please need help.
My current firmware ver is 1.1.1.06
Please refer to my speedtest below
6 Replies 6
We have the same problem, have you find a solution ?
(Firmware : 1.3.1.12)
Best Regards
Thomas
France
Bast
I've reported this issue the last week (https://supportforums.cisco.com/discussion/13103401/rv325-does-not-support-gigabit) and the problem has been resolved.
1/ You have to update your firmware with the last one released (v1.3.1.12)
2/ In System Management > Bandwidth Management you have to clear all the parameters (as well Rate Control as Priority)
Once you do that, it should be okay.
Thanks William,
But we can't clear all parameter, we have this alert "The value (Upstream or Downstream) is out of range [1~1000000]!"
You don't need to clear these parameters (only those in Control Rate and Priority). You can fill in with the max size (1000000) for both.
Thanks, but still the same problem ...
Did you reset the configuration before upgrading?
