RV325 VPN multiuser problem
omar Viera
Hi All
I've been searching for a while without finding a good way to resolve my issue. I got an small business network that goes.. one main site using a Rv325, and two secondary with RV320
all connected through the IPsec Connection. I got a easy vpn connection that was working fine, until another user was in need for connect.
Here is my problem.
If one user is connected no other user can connect using the Easy vpn.
This is what I tried
 - create another easy vpn connection but still the same thing.
 - assign more IP on the vpn range. still the same
 - I was thinking that the active-directory authentication was the problem... so I create local users  - No luck...
the software that I'm using is the Cisco VPN client 5.0.07.0290
Any Help will be appreciated...
Ami Xiao
I'm able to established ezvpn connection with multiuser, not sure what your group settings are, it should be Unassigned for ezvpn.
CiscoSMB
We had the same issue.  The problem was the firmware on the router.  I believe the version with the issue was 1.3.2.02.  I upgraded to 1.4.2.17.  This fixed the issue.  Beware, 1.4.2.17 has a login issue if you use the VLAN option.  You have to have VLAN with DHCP to login in the router on at least one VLAN.
