RV325 WoL possibilities
ntothmolehand
I'm wondering is it poosible to set Wake on LAN feature on RV325 router? Can it set as a delayed.action?
If the answer is yes, please tell me how, step by step.
Thank you!
slstratt
Hello ntothmolehand,
Thank you for using the Small Business Support Community!
Unfortunately, the RV325 does not support the Wake on LAN feature. If you have any other questions, please feel free to post them here and I'll do my best to help you.
Best,
Taylor
Thank you for your fast answer, you helped a lot!
I'm done with the questioning for now
thank you again.
Why wont you support it, its simple stuff. Even the cheap consumer models does support it.
