RV325 won't boot
rleffew01
Bought a new RV325, programmed it, then went to update firmware. Firmware never finished updating after waiting 4 hours. Diag blinking red the whole time.
Power cycled, power blinking green, diag steady red -- over an hour. Power cycled a couple times, tried "reset" button too. Nothing.
Advice?
Roy.
15 Replies 15
Hi Pricefloyd.  Can you provide additional details on how you access the RV325 via port 69?
I did some work on the self sign certificate yesterday (brand new unit) and now I can't access my unit.  I followed a number of suggestions via tftp-ing an earlier firmware but i just a message "connect request failed".
I tried using the gui on another suggestion via port 8007 and can see the login but it won't take the default password.
So now I can't seem to get into the unit to do anything and I'm getting desperate as I have remote work to do this week and I need to get this up.
I would like to try your method of this port 69 thing....., can you share the software and the process you use please?  Much thanks
