RV32x Remote Management
wayne.ranchuk
Hi All
I am having an issue with remote Management not working in the RV325 and 320 routers. when i reboot the router it works but after 24 hours i cannot access the remote management until i reboot the router again.. I never had any issues with the RV016..
let me know if there is a fix for this issue I am using firmware v1.2.1.13
thanks
Wayne
Michael Swenson
Thanks for contacting Cisco.
Please upgrade the firmware to 1.2.1.14, link below.
https://software.cisco.com/download/release.html?mdfid=284005929&softwareid=282465789&release=1.2.1.14&relind=AVAILABLE&rellifecycle=&reltype=latest
If the issue continues, you should reset the device to factory defaults and manually reconfigure the device.
Best Regards,
