RV340 and SNMP
pasquall
I have a brand new RV340, did firmware upgrade to 1.0.03.15, reset to factory settings after upgrade.
I'm trying to monitoring it's interfaces, tried with Cacti and Zabbix, no success.
Debugging I find out that doing smnpget I can't see counters increasing over time, but when I run smnpwalk it seems that counters get updated. Even so, counter of In packets are the same of Out packets!
Does anyone know what is going on? Or how to debug?
7 Replies 7
GiullioV
hello my version is 10.0.03.22 and i'm having problems with zabbix too, graphics keep cutting all the time!
Before it was working normally!
Through snmpwalk I get a response from my router correctly! but on zabbix the graphics are failing!
After upgrade to 1.0.03.22 solve our problems.
I don´t have zabbix here to test, but it works on Cacti.
Hi, Can you please give me OID for monitor RV340 WAN1 and WAN2 port? I'm trying many way to use SNMP such as scan all MIBS files or walk many of OID, not found something to report the traffic usage.
Hi, Yes Sure... I will arrange for you. And I bring it here.
Many thanks ;} I waiting for it.
Hello friend, below is the requested information, I hope I have helped!
I used the "snmpget" command to get this information:
snmpget -On -v2c -c "Community" "IP" IF-MIB::ifOutOctets.[...]
IF-In
IF-MIB::ifInOctets.33  = WAN1
OID: .1.3.6.1.2.1.2.2.1.10.33
IF-Out
IF-MIB::ifOutOctets.33 = WAN1
OID: .1.3.6.1.2.1.2.2.1.16.33
IF-In
IF-MIB::ifInOctets.34 = WAN2
OID: .1.3.6.1.2.1.2.2.1.10.34
IF-Out
IF-MIB::ifOutOctets.34 = WAN1
OID:.1.3.6.1.2.1.2.2.1.16.34
Thanks for your advise. but I'm still cannot get any value from provided OID. There's my log.
- Scan single OID. 1.3.6.1.2.1.2.2.1.10.33
16/11/2021 11:49:57 (2 ms) : SNMP V2c
16/11/2021 11:49:57 (2 ms) : Custom OID 1.3.6.1.2.1.2.2.1.10.33
16/11/2021 11:50:02 (5015 ms) : SNMP Datatype: ASN_PRIMITIVE
16/11/2021 11:50:02 (5018 ms) : -------
16/11/2021 11:50:02 (5020 ms) : Value: No response (check: firewalls, routing, snmp settings of device, IPs, SNMP version, community, passwords etc) (SNMP error # -2003)
16/11/2021 11:50:02 (5021 ms) : Done
- Walk 1.3.6.1.2.1.2.2.1.10
16/11/2021 11:50:26 (3 ms) : SNMP V2c
16/11/2021 11:50:26 (4 ms) : Walk 1.3.6.1.2.1.2.2.1.10
16/11/2021 11:50:31 (4543 ms) : 1.3.6.1.2.1.2.2.1.10.2 = "0" [ASN_COUNTER]
16/11/2021 11:51:31 (4 ms) : SNMP V2c
16/11/2021 11:51:31 (5 ms) : Walk 1.3.6.1.2.1.2.2.1
16/11/2021 11:51:36 (4597 ms) : 1.3.6.1.2.1.2.2.1.1.2 = "2" [ASN_INTEGER]
16/11/2021 11:51:36 (4620 ms) : 1.3.6.1.2.1.2.2.1.2.2 = "WAN1-PPPOE" [ASN_OCTET_STR]
16/11/2021 11:51:36 (4645 ms) : 1.3.6.1.2.1.2.2.1.3.5 = "160" [ASN_INTEGER]
16/11/2021 11:51:36 (4671 ms) : 1.3.6.1.2.1.2.2.1.4.2 = "1500" [ASN_INTEGER]
16/11/2021 11:51:36 (4691 ms) : 1.3.6.1.2.1.2.2.1.5.2 = "0" [ASN_UNSIGNED]
16/11/2021 11:51:36 (4752 ms) : 1.3.6.1.2.1.2.2.1.7.2 = "1" [ASN_INTEGER]
16/11/2021 11:51:36 (4786 ms) : 1.3.6.1.2.1.2.2.1.8.9 = "1" [ASN_INTEGER]
16/11/2021 11:51:36 (4850 ms) : 1.3.6.1.2.1.2.2.1.10.2 = "0" [ASN_COUNTER]
16/11/2021 11:51:36 (4872 ms) : 1.3.6.1.2.1.2.2.1.11.2 = "0" [ASN_COUNTER]
16/11/2021 11:51:36 (4987 ms) : 1.3.6.1.2.1.2.2.1.14.2 = "0" [ASN_COUNTER]
16/11/2021 11:51:36 (5054 ms) : 1.3.6.1.2.1.2.2.1.16.2 = "0" [ASN_COUNTER]
16/11/2021 11:51:36 (5073 ms) : 1.3.6.1.2.1.2.2.1.17.2 = "0" [ASN_COUNTER]
16/11/2021 11:51:36 (5174 ms) : 1.3.6.1.2.1.2.2.1.20.2 = "0" [ASN_COUNTER]
