07-07-2018 11:50 PM - edited 03-21-2019 11:12 AM
I logged in my RV340 last week to find a message to say a new firmware 1.0.02.9000 was available. I was rebooting because of a problem I was having, I didn't do the update. Now when I go back in to do the firmware upgrade, the message has gone. On the downloads page on cisco.com it still shows 1.0.01.18 and when I do a check on the router in the Automatic Updates section for a new version, I now get " Get system/USB Modem/Security firmware information fail." so am I doing something wrong?...
Solved! Go to Solution.
07-09-2018 10:43 AM
My name is Iliya Gatsev from Cisco Technical Support Team.
No worries. Officially the latest firmware is still 1.0.01.18
Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
07-09-2018 10:43 AM
Iliya Gatsev
07-10-2018 02:12 PM
I downloaded the 1.0.02.9000 update that was released. Since then my router is intermittently losing PPPOE connection / authentication. The connection status goes to 'DOWN' after a reboot and possibly other times as well.
I guess I should roll back to 1.0.01.18 ?
Can I ask what happened to 1.0.02.9000 ?
09-04-2018 12:13 AM
hi, I had also encounter the same issue. router prompt a new firmware 1.0.02.9000. May I know if 1.0.02.9000 is an official firmware?
