04-06-2019 01:44 AM
My router will load most webpages but a few it will not. Of particular interest "http://alaska.gov" Here is what I've done.
1. First router was taken out of the box, updated with the latest firmware and configured with a number of Vlans - that failed.
2. Reset back to factory default, set ISP credentials - that failed.
2. Removed the RV340 router and put in its place an RV320 - that works.
3. Purchased a second RV340 took it out of the box without any updates or configuration other than ISP credentials - that failed.
Please keep in mind most websites work just fine, I actually like this thing, just that some fail. Too, I do not have a PC with an RS-323 port making the command line inaccessible. If it's of any consequence I cannot download cisco firmware from their site with the RV340 it requires an RV320.
I sure would appreciate any help.
Thank you,
Reese
04-07-2019 10:51 PM - edited 04-07-2019 11:00 PM
I am running a RV340 router on an older version of firmware. I clicked on your link with the Alaska web pages and they all seemed to paint fairly fast. I tried random ones. Do you have a particular web page which does not work?
04-07-2019 11:50 PM
The webpage I listed is one I need and is the biggest problem, no home page. Thanks for testing it out! The local library's webpage will not load the User portal my wife signs into. Too, I get an error message on the Cisco support webpage when I click on the download tab, too I can't log into my Cisco account. The router works fine with the majority of sites.
The first router is using firmware version 1.0.02.16. Too, the error log doesn't indicate a problem.
I've managed to connect the RV340 Wan port to a port on the RV320, the 320 Wan port to my ISP and the webpages pass through without hesitation.
I recon my next step is to contact my ISP, I doubt there are going to be of much help.
Thanks again for the feedback!
04-08-2019 08:15 AM
You might try using nslookup on the web pages which don't load and ping or traceroute the IPs.
I also have no issues Cisco's firmware. I just google RV340 firmware. Select the Cisco link which is the top link for me. Then select download. The firmware is right there.
04-09-2019 11:07 PM
I wish to thank you for the advice.
I able to get a successful result using the nslookup for the alaska . gov URL. But the page fails using either Explorer or Fire Fox. Typing in the IP address didn't work either.
Below is a snip of the Cisco webpage when one selects the 'Downloads' tab.
04-10-2019 03:26 PM
I am on that web page all the time including just a minute ago. I think it has nothing to do with your RV340 router. I don't use IE or Firefox either. I use Microsoft Edge. Sometimes Chrome but not very often.
